Hi,
I am cladding some walls and would appreciate any advice/suggestions.
The choice of cladding material will be supplied to me as 8' x 4' sheets - three in total.
On the facing side is Formica F9012 Ebony HGP (Horizontal Grain)
The backing material is 12mm MDF
The balancing material is white Formica
To see the facing product (http://www.formica.co.uk/publish/site/e ... rains.html)
After getting the sheets supplied to me, I will leave for a few days to settle. Then I will cut to size.
I was then going to take some timber cutting it at an angle. Half gets fixed to the wall, the other half to the Wall cladding (non facing side). This should then let me lower the sheets (cut) onto the wall which should then provide a straight guide.
The height of the panels to be hung will be 1200mm with the grain running horizontally. As such I will use three peices of timber to secure the cladding. Top, Middle and bottom - leaving room for maneuvering to top and bottom.
A. My concerns is if 12mm is a thick enough MDF - I am not sure what "commercial" people use. Keep in mind this does have White Formica to the rear to balance - so it should be pretty good. But I will only have 10mm that I can screw into.
B. What techniques can be used to allow minor vertical alterations - just incase - are we just looking at putting simple packers on the wall mount ?
A place called Mitchells Worktops (http://www.mitchellsworktops.co.uk/) are sourcing the Formica and MDF (James Lathams), doing the glueing up and putting into their 8' by 4' laminate press. They are charging £187/sheet. Which I thought was not bad as it's all custom stuff - with finishes / sizes to my spec. I got two other quotes and both were £45/sheet more expensive.
Before anyone suggest, the finish is exactly what I require. I have been to James Lathams new (absolutely massive) new warehouse in Fareham and they did not have a finished product that I liked ! But my god, did they have some stock !!
Paul.
[/url]
Paul.
[/url]
