• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Found Veritas low angle jack blades - 38, 50 and toothed!
dazzer
4 Jun 2011
Worcester
Hi all
I thought I would ask on the forum if anyone has any Veritas low angle jack, 38, 50 degree or toothed blades they wanted to sell, before I buy from a supplier.
Dave
Hi all
Dave
Hi Dave. Can I suggest that you buy the standard blades (25 degrees?) and put on your desired 38 or 50 degree bevel as a mirco-bevel. That makes it much easier to experiment with different bevels to suit differring timbers. I.e. it's much easier to reduce the cutting angle by 5 degrees on a 25 degree iron with a 50 degree micro-bevel than it is on a 50 degree iron (in the latter case you would need to regrind your primary bevel).
Cheers, Vann.
