Unexpected gift
sawdust maker
24 Jan 2007
East Yorkshire
Three weeks ago I bought a fixed base router of ebay. The ones that B&Q used to sell. Only £17 so thought it was a bargin, and it was. fitter it in a router table. It worked so well I bought another. It came within days of sending the money. now the surprise, todays a third was sent to me! i thought this was a mistake so emailed the seller. Got one back saying it wasn't a mistake it was sent as a gift. The seller was Benjis.co.uk (who I have no connection with other than being a very satisfied customer) They appear to specialise in selling reconditioned tools.
Cheap is good but how do they perform...no point having three if they are all rubbish.
Hi George
The router appears to work very well mounted in a table. I intend to put some photos on here showing how I have modified so it works better as soon as get chance. I wouldn't recommend it as a hand held router a plunge router is more versatile.
Paul
My experience of cheap routers:
I think the one I had was a 'Ferm' of Firm'. For what it cost it was okay.
I suppose it depends on how much woodwork you do.
One of those cheapo models might well serve a hobbyist quite well, if they're used just once or twice a week.
I can't see a professional being satisfied with a short life tool though. I could always be surprised, of course and someone will have one that goes on and on!
Yes cheap routers would never do for the professional woodworker, and I am not one. However the router were originally sold by B&Q at £100+ but didn't catch on. They have one big problem. The router couldn't be taken out of the base, so changing the cutter is difficult with limited access. Also the router cannot be locked on so use on a table was difficult. On the plus side it is variable speed, soft start and takes 1/4" and 1/2" cutters so the basic router appears good. The alterations I made are as so; power to the router comes into the handel and then by a short cable into the router motor. This cable is not long enough to alow the motor to be removed so I extended it and put in a 10 amp straight connector. This alows the router to be removed fully form the base, once a small screw has been removed, and solves the problem changing the cutter. As I have two on the base I have fitted to the table I have removed both handels and connect the router via the 10 amp connector to a NVR switch.
Paul
