The Swirly Toped Box.
OK - that's a wow from me........
the obvious question from someone who's not made a lid like that is 'how do you get the dimensions of each segment to ensure that you get accurate 360 degrees when put together?' Do you 'just' start with the normal segment angles etc then replace two faces of the triangle with a duplicated arc?
great effect
thanks for the detailed outline as well
jumps":2hz15sfm said:
...... 'how do you get the dimensions of each segment to ensure that you get accurate 360 degrees when put together?' Do you 'just' start with the normal segment angles etc then replace two faces of the triangle with a duplicated arc?...
Yes
All I can say is WOW, love it, lots of work in this one. =D> =D> =D> =D>
