Single handed planer
manxnorton
29 Jun 2016
Newcastle
Hi all,
A quick one!
Help with a single handed plane, will be appreciated?
I have only one arm able to use hand tools, and I would love to get my wood with a plane.
I'm thinking a small plane with the adjustment fine & my wood firmly clamp downs.
Thank you
ATB
Bri
I don't know, but having to do things quickly sometimes standing on one leg I'd be tempted to try something like a 5 1/2. - you may find the bit of extra weight steadies your cut. Is there anyone you can borrow a couple from to try? You could try mine - but I think a near thousand mile round trip is a bit much :D .
Would the Japanese planes help? They cut on the pull stroke I believe , which I imagine would be much easier to control one handed? Not sure about adjusting setup though. :)
+1 for a block plane it's the only one I use one handed.
My first thought was an Asian plane as Matt suggested, but they're a non-starter I fear. I can't think of how I'd adjust any wooden plane properly without holding it and tapping with the other hand.
So I'd also plump for a block plane. They're small enough to fit in one hand and they have a very simple mechanism that doesn't require two-handed adjustment.
Block planes come in two main types, low-angle where the iron (the blade) is set at something like 12-15°, and the standard block plane where the iron is set at 20° or so. Low-angle block planes are primarily intended for working end grain, standard block planes are more for face grain.
If you want the most versatility with the one plane I would get a low-angle type and buy a second iron. The first iron you'd sharpen conventionally at a lowish angle and the second you would sharpen to a much steeper angle which will improve performance on face grain. The honing angles would be approximately 25-30° and 40-50° respectively.
Good morning all,
Thank so much for the advice.
I haven't started looking on the block plane yet, just finnishing my daily exercises & I think our lass wants to go food shopping :)
I'll report back to you soon!
What I seen about a power planer is too much lol
I'm slowly getting my hand tools together, but more practice marking the joints with one hand..ok with the grain with a set square or joiner bevel n a clamp (using a small blade knife)
But I'll get there :)
ATB
Bri
Had a look at the net for block planer.
The question now is which one?? Properly going to price and what I want to use it for.
Small item at the minute like small boxes etc.
Once again too many to chose from lol
ATB
Bri
Axminster s own block plane is a bit bigger than most I think.
I bought what I think was an end of a line one.
It was half price and although it didn't get a very good write up has been excellent
In your situation you need to try before you buy, maybe a local member will help
A block plane is the obvious thing to get going straight away, but then I started wondering if a longer, wooden plane could be made so that it could be used with a central grip and lots of downward pressure (I would have thought that a bench a tad lower than usual would be useful if one can only use one arm). It shouldn't be beyond the wit of man to cut a suitably shaped hand grip onto the upper surface of e.g. a 14" long plane. Any plane makers care to comment as to the feasibility of this?
MattRoberts":zi57eux4 said:
Check Ed's recommendation for a low angle block plane Bri :)
Hi Matt,
I know a 'type' but don't know which one (the name)
Sorry guys I have also certain problems with working out certain info (leArning difficultys) but I'm getting better all the time, like my wood working practice, practice.
ATB
Bri
The Quangshen low angle block planes from workshop heaven are excellent out the box and the 3 iron option basically gives you 3 planes in one for the sake of convenience at least. A little pricey but excellent value for the quality.
If you want a plane that doesn't need fettling, don't mind paying a little more but be assured it will work well for you from the start they are well worth a look. Lovely bit of kit
http://www.workshopheaven.com/tools/Qua ... ype-3.html
Not for everyone but it might suit you. They are slightly discounted at the moment.
Cheers,
Chris.
Great idea m8!
If there's a member near or in Newcastle Upon Tyne that has one I'd be chuffed to get a shot of one...before I buy.
Tbh that leads me to trying a small one and cheap!! If I just buy n try!
ATB
Bri
Dear Bri,
Might I ask, are you missing an arm? Do you have one had that's much more able than the other? Could you explain a little more about the disability you're struggling with please?
Sorry about the personal questions, but I fear you' ll be frustrated and disappointed if our suggestions don't work, and I think we need a bit more info, in order to best advise you.
If I could explain about my own situation: it's probably not as severe as yours, but you'll get the idea:
I've had arthritis since I was around 27, that's thirty years. It happened suddenly after serious food poisoning whilst working in the Himalayas (I nearly died from the bug itself). Although initially it was rheumatoid (which you can do a lot about), it triggered early-onset osteo-arthritis, which really buggers things up.
So now I don't have any normal fingers left, my grip is probably 1/3 or less than normal, and standing on a hard floor doing bench work can be horrid after a couple of days. But like you I'm not giving in to it. It's what we want to do, because woodwork is really satisfying and rewarding.
OK, so how do I cope?
Thing #1: I'm becoming obsessive about sharpness. Whatever edge tool I'm using, and that includes saws, I need to keep it sharp. In the old days I didn't care much, and pushing a blunt something-or-other through the wood was just a slight nuisance. Now it's a right pain. Never mind finish quality, accuracy and so on, it needs to be sharp because I probably can't use it if it's blunt. I can't steer whatever-it-is straight.
if you want to use chisels, or planes, or knives or saws (to an extent), you'll need to find a way to get them really sharp, and keep them that way.
I have a suggestion on this. I started using Scary Sharp a few years ago, and get on with it well. I wouldn't recommend it though in your case if you only have one hand to use, as I find I need two hands to steady the blade (I use a honing guide though, and you might find one that suits). The biggest thing in its favour though is that it seems to be idiot-proof - I got really good results the first time I tried it. Give it a try, because if you can use it, it's easy to get good, consistent results. But there's another way, too:
I also bought a Tormek-style slow-speed wet sharpener a few years ago. It took me ages to get on with it. Until recently I just used it for scissors, kitchen knives, and rough grinds of woodworking tools. But I think I was trying too hard or something: my next-door-but-one neighbour was struggling to do some fencing with chisels that were basically wedge-shaped lumps of steel - no edge whatsoever. So I offered to sort them out, and in a short while could dry-shave with them (forearms only!). It just happened, and it was pretty quick. I wasn't expecting it to be as good as it was.
The thing about those grinders is that you CAN use one hand. The jigs slide on a bar, so you're guiding rather than holding the blade in position. OK, I do kitchen knives freehand, but there's always something to rest against, so one-handed is quite possible.
Whatever plane you choose, the sharpening thing will be the real make or break. If you can get your edge tools really, really sharp, and keep them that way, you'll be fine. Otherwise you'll struggle a lot, especially with planes.
Finally, on planes: basically, try a range of tools until you find some that are comfortable.
You will need to be aware of the angle - not the angle you sharpen at, but the angle the iron makes with the wood: as a general rule, low angles for cross-grain work, higher angles for planing long boards and edges, and really high angles for awkward grain, to avoid tearout. If you get a bevel-up plane, you can change the angle when you sharpen (and have several angles if you have several plane irons to fit your plane). If you have a bevel-down plane, like the traditional Bailey pattern #4, #5, etc., it's not quite so easy*.
Finally (my twopence-worth lasts for ages!), you can PULL traditional Western planes, rather than push them. There's no law against it. I often do this, especially with shoulder planes on Tenon shoulders, etc. OK, the handles are set up for not doing this, but you can, and I often do. On a Bailey-pattern plane (numbers #4, #5, #6, and #7 and the half-sizes), it works too. as long as they are very sharp and you set them carefully.
It is much more controllable pulling a Western plane one-handed than pulling it. If you add-in that you can probably swap the knob (at the front) for a custom handle to help you get the best grip and control, that may be a good solution. I only have one block plane, and that can be pulled comfortably too, but it's not suitable for planing big areas.
Hope that's useful. Whatever you buy, sort out a comfortable and effective sharpening method as soon as you can, to avoid a lot of frustration.
Regards,
E.
*Google David Charlesworth's "ruler trick", for putting a tiny bevel on the upper side of the plane iron, for difficult woods - works a treat.
I have a couple of Qs.
1. Do you want to be able to face plane to smoothish finish from sawn?
2 can you move the duff arm at all at least to put it on the top of a front knob to apply a little down pressure, even if just by weight?
If yes to the above (maybe even 1. yes 2. no, then maybe a wooden plane about the size of a #6 but with a bailey frog etc maybe what you want.
The longer length will give you better control to use it one handed and hte wooden body less tiring to use
if I did this right re pics they should be viewable here. sorry for basic pics but just to give basic idea as such. would also suggest having the bench higher maybe around 38"
    14.6 KB
    10.2 KB
Eric The Viking":2ijeywdj said:
Dear Bri,
I've had arthritis since I was around 27, that's thirty years. It happened suddenly after serious food poisoning whilst working in the Himalayas (I nearly died from the bug itself). Although initially it was rheumatoid (which you can do a lot about), it triggered early-onset osteo-arthritis, which really pippers things up.
Regards,
E.
Hello Eric,
Not a problem m8 talking about my disibilty.
I suffered 2 strokes one after the other and managed to survive 11 hrs before I got found.
Lost the whole left side of my body and my brain, memory, speech, communication probs (like rational thinking) reading, writing, even simple thinking I can get confused.
For all a learnt to stand on my two feet (nearly) and my arm and fingers (left hand) were getting better.
But now since Xmas I've lost the feeling in my left leg and my left arm.
The movement is slow robotic movements..and my grip is done.
So I have to get Botox (wish it do my face!!) to stop the arm going back to a spastic arm. Keeping it down when I move and try to other tasks about the house.
Ohhhhh!!! Well I've tried and I still do my daily exercises including finger exercises...with no change..BUT I WILL NOT GIVE UP! :lol:
Sharpening tools is not a problem..if I can't do them (being a custom knife maker) learning by my mentor, he will sharpen them for me,..and they are the sharpest tools I've ever seen.
He's already volunteered to sharpen al. My tools inc the 3 cheap chilcels I bought a few days ago! I've started my regime of sorting out the initial state of them.
I'll buy the right one (I think) and see how I go!!
Thanks pal,
ATB
Bri
MattRoberts":1gu02b7y said:
manxnorton":1gu02b7y said:
Hi Matt,
Sorry Bri, low angle block planes are a very common type of plane, so any of the good brands like Stanley, Lie Neilsen, veritas etc would be fine. Axminster also do their own :
http://www.axminster.co.uk/hand-tools/p ... ock-planes
Hi pal,
Don't need to say sorry m8, it my fault for not telling you I have problems my tiny brain haha!
Humour is the way ahead! Full career in the army bein 5' 6" and a Georgie with a unusual sername, I had to take it on the chin.. :mrgreen:
Anyway I'm thinking this one:
http://www.axminster.co.uk/axminster-ri ... ane-506559
I think (my thinking is messed up!) this will be all round and can cut end grain...
What u think?
Nearly there with choosing one anyways lol.
Mind you should see me put a clothes rail up on our lasses wardwrode!! Haha!! Balancing the post in my head whilst trying to tighting the screws!!! An hrs work!! He!he! But I got there..mind time for a sit down..
ATB
Bri
A sightly off the wall thought - could a plane be modified by adding a forearm or elbow rest at the rear.
The front would be held as normal and the rest elbow/arm rest would allow the plane to be guided and body weight used. May be easiest to modify a wood block plane where the rear wooden handle could easily be replaced with the forearm rest.
Terry
