Sanding on Poplar
GrahamIreland
4 Jun 2015
Nottingham
Hi I have applied a coat of Osmo polyX oil/wax on a bench I've made.
It's like a poly-urethane.
I sanded with just 100 grit before hand.
The finish feels fuzzy,
Can I sand down now with a finer paper and just leave it.
Or do I sand down and apply another coat?
Would a wax help?
Work bench or seating bench?
Work bench, leave it, you don't want it too slick.
Seating bench, sand down with 150/180 grit, then again with 220/240 grit, then re-coat with three coats of Osmo. I'm all for avoiding sanding down to pointlessly fine grits, but 100 grit is just too coarse for furniture and besides, Poplar is a tight grained timber capable of delivering a very smooth finish.
Cheers custard. Yes seating stool.
I'm so used to working with old reclaimed woods where you can get away with a rough sand!
Ok, I'll start with some finer papers and give another coat or two.
Thanks again
Graham
Can I just check Graham, are you sanding by hand with a block or using a ROS?
