Aled Dafis
Hi guys, it's been a while since I posted here, I hope you're all well.
I need some new sanding arbors and was hoping that you could point me to the best/best value ones around.
I generally use the 3" pads but have in the past cut them down to say 70mm so that the paper overlaps the sides a little.
Do you have a dedicated pad for each grit or do you just swap grits?
Aled
Aled
