I did a place 20 years ago by capping with plastic. Still going strong. Wood was fine but needed repainting. By a good quality plastic and it won't yellow. I know it doesn't suit everybody but I can't stand painting and if you have uPVC windows already I don't see the issue. You will also need to redo all the guttering with the correct fall and make sure the felt or barrier go over the top of the plastic to avoid moisture getting in behind. I now live in an Arts & Crafts house in an AONB so I wouldn't use plastic because it would be wrong, but for low maintenance on the right house I'd do it again.
