Good Surname or what ?
Just received this email from a friend. As you'll see he had a problem with an unsightly stain. He called for advice and I read to him from one of David Charlesworth's books. It seems to have done the trick.
Hi Phil,
Great news!
Now, not only can you eat it in your crumble, your pavlova or melba but you can also use it to rescue your oak window frames. This wonder vegetable continues to exceed all expectations!
As you know, the problem was self-inflicted - wire wool used to dress the interior of the frames. The (ferrous) wire dust blew outside onto the cill and, aided and abetted by rain, inked the oak cills in a pretty gun metal blue - from end to end.
To remove, I applied the oxalic acid for about 25 minutes (applying more as necessary) and when the last stain had gone, neutralised with Borax in water.
Fantastic.
And, it just when you think it can't get better - it does.
Not only did it remove the ink but also cleaned off the fly dung - its a miracle cleaner! Listen mate, this stuff is hot. When the news gets out prices are heading to the moon. I've just dumped, I mean sold, my Iraqi Dinar holdings "at market" and moved into Oxalic acid futures - that's where you should be putting your money.
I can honestly say, Oxalic acid has changed my life.
Cheers,
A
PS You don't think that last line makes me sound a bit, kind of, anoracky do you?
