duncanh
These have been turned over the last 3 months or so, but I've only just got round to posting them...
click images for a larger version
This is my first natural edge vase. Made from wild cherry from my dad's garden. Height is approx 19cm. Finish is danish oil. Hollowed mainly with Monro tool. Turned wet
Lacewood. 10cm high x 15cm. Finish is danish oil. Hollowed using Sorby straight multi tip hollowing tool.
click image for a larger version
Silver birch from my dad's garden. 17cm high x15cm. Hollowed with the Monro tool again. Turned wet. Danish oil finish. Unfortunately the base on this developped a crack within 4 hours of taking it off the lathe. You can see the super glued fix in the picture. It was only afterwards that I thought I should have put some aluminum powder in it to make a silver fix in the silver birch.
Silver birch. 14.5cm diameter x 2.5cm high. Danish oil finish. From the same tree as above - made from an odd branch that I didn't want to waste.
Yew natural edge bowl from a tree in the graveyard in the village where I grew up. Approx. 20cm diameter x 12cm high. Turned wet. Danish oil finish
From the same yew tree as above. 13cm diameter x 8cm. Turned as an experiment - it's cross grain and contains the heart and pith, which all everyone says not to do as it's likely to crack. Well, this has a little, but it's not huge. Turned wet. Lemon oil finish.
To enable me to sand most of the wet pieces I sprayed them with meths which I then lit. It's a technique I saw Jimmy Clewes use and it works well. The larger ones needed to be sprayed several times.
Unfortunately my shed's unbearably hot after just 10 minutes of working at the moment, so it'll be a while before I have anything else to post.
Duncan
Duncan
