simuk
When setting out tenons on a middle door rail, if the tenon width exceeds 6 times the tenon thickness do you just enlarge the middle haunch, to reduce tenon width?
Thanks in advance
Simon
Thanks in advance
Simon
twothumbs":3iag8epw said:You can nowadays get very good long backset 'latches' to suit older doors. About 6", but locks are not so easy but do you need to lock internal doors. The other way was to use 'budget' or face fix if it is a cupboard or servants rooms!. Hope this is of some interest.
Eric The Viking":20724gk9 said:I'd be keen to know another source for those mortice locks if you have one, as the ones I linked-to aren't cheap! They're also as you say - rather empty inside - and a narrower (top-to-bottom) case would be better.
E.
