phil.p":2ddjyq5q said:Mine ran perfectly well on engine oil for forty years.
chipmunk":6tcs1kda said:The bearings on an ML7 and ML8 are entirely different (white metal plain and angular contact ball races respectively)
phil.p":1bcyhja2 said:It would seem a little strange to choose a thin oil for a bearing arrangement that that makes no attempt to contain the oil - the seal might just as well not be there.
parvum":qgm5as5u said:In my experience Nuto 32 is available from only a few specialist suppliers at an exorbitant cost for 1 litre bottles or more reasonably on a per litre basis if you buy 25 litres.
parvum":qgm5as5u said:To reassure you there are no clutches in the bearing assemblies of a Myford Ml8. Vide lathes. Co . U.K. ATF if formulated to lubricate,cool and operate automatic gearboxes which usually have clutches in their innards.
