RossJarvis
I believe International Woodskin is popular in the yachting fraternity. I recently used this on an oak door and found that although it seemed to go on reasonably smoothly and well, when dry it seemed to "pool" a bit in some areas and wasn't totally even. It's quite thick, so I'm thinking that it forms thicker areas where it first goes on from the loaded brush and despite working, doesn't really spread evenly. "Thinning is not recommended" states the label, so maybe it's not too easy to get a very smooth spread of the stuff.
Has anyone used this stuff and noticed this trait and if so, have you found a good way of evening it out?
The instructions recommend using a stiff bristle brush, but I was using a stiff synthetic brush, would a stiffer brush make a difference?
