Hi, I'm new to the forum, so thanks in advance for any help given...
OK, I'm wanting to make a workshop from my shed, and here are the basics:
What's there already:
The shed is 8' x 12', made of 2' wide vertical concrete panels.
It has a 4' wide wooden door and a window. The floor is a big flat concrete slab.
The roof is corrugated and sloping - I think it's corrugated concrete or some fibrous hard stuff.
The roof is watertight. The floor/wall join is fairly basic, in that the wall slabs are just sitting on the base. I've sealed it with exterior frame sealant.
There are chunky wooden worktops and shelves along some of the longer sides.
There's electricity, with lights and sockets, but it looks dodgy.
In the winter when it was really cold and then warmed slightly, there was condensation in the shed with lots of drips from the roof.
What I want to do:
I want to make it into a workshop where I can work on my lathe, bandsaw, etc. I'll keep the worktops/shelves where they are.
I'd like to insulate the walls/floor/roof
I want to get the electrics taken out and re-done (will get an electrician in for this)
I may only be living here for a few years rather than many years, so I'm not looking for a 'dream-workshop' solution. Just a 'basic but good' solution.
Ideally I'm looking to do this myself (apart from the electrics) so simpler solutions would be better.
Here are my questions:
What would people suggest as insulation material for the walls, floor and roof? With the wall insulation, I need something that will cut easily, so that I can fit it around the shelving/worktop structures.
What would you suggest about ventilation/condensation?
Would insulating the whole shed mean that winter condensation is less likely to happen? Or do I need to put a ventilation grill of some sort in the door to get air flow?
When I insulated it, would the door and window just let in the cold air because they're not insulated, or is this not a big deal?
I'm guessing it's best to sort out the electrics first, then fit insulation round it - is that best, or the other way round?
I think that's about it...
Thanks ever so much if anyone can offer advice or suggestions It's very much appreciated!
What I want to do:
