woodfarmer":uatr2awg said:
....... There is a potential split low down on one side of the base (see first photo) so left enough wood for it to survive this if it happens. It is 3/4 inches thick (20mm) at the rim and 1 1/4 (32mm) inches thick where the split might happen.
Good to see you using the tools and tackling the new wood pile but I would advise caution on working too many pieces that wet to that thickness. I would estimate that there is an 80/20 % chance of the yew piece splitting quite severely unless you do something more than just a wax rub to control the speed and direction of the drying stresses.
Leaving the base thicker than the sides is not a good idea, it will dry out slower and as the sides shrink in circumference something may have to give.
