This may ring a few bells for Niki as well.
That magic Oz humour!
Remember, it takes a college degree to fly a plane but only a high
school diploma to fix one, but never let it be said that ground crews
lack a sense of humor.
After every flight, Qantas pilots fill out a form, called a 'Gripe
Sheet' which tells mechanics about problems with the aircraft.
The mechanics correct the problems; document their repairs on the form,
and then pilots review the Gripe Sheets before the next flight.
Here are some actual maintenance complaints submitted by Qantas' pilots
(marked with a P) and the solutions recorded (marked with an S) by
maintenance engineers.*
By the way, Qantas is the only major airline that has never, ever, had
an accident.
(That should read 'Serious Accident!')
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute
Descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what friction locks are for.
P: IFF inoperative in OFF mode.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing. (Loved this one!)
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And the best one for last..................
P: Noise coming from under instrument panel. Sounds like a midget
pounding on something with a hammer.
S: Took hammer away from midget.
Roy.
an accident.
Descent.
S: Cat installed.
Roy.
