FAO MarkMc re: Add On Fences thread on UKWW
A
Anonymous
Guest
The part you're looking for is available via mail order from RS Components. Just put the part number in the advanced search and there it is. Even if you don't buy from them, you can see all the various profiles that are available by using the links at the top (Bosch Basic Mechanical Elements is what you need to look for)
Sorry about using this forum to comment on a thread elsewhere, Charley, but as I'm not a member on UKWW it seemed the only option. Hopefully Mark drops in here, or else someone can pass the info on.
Cheers, Alf
Signal
23 Dec 2002
hiya Alf,
I copied you post over to UKWW for you.
Hope you didnt mind
Signal.
ps not seen you around latley you ok?
