Paul200
Hoping someone here can help with this one.
Recently moved into a 150 year old stone built cottage with concrete floors. Original walls and floors have no dpc or membrane that I'm aware of but recent extensions (20 years?) have concrete floors over a dpm. At the back door the concrete sill is simply an extension of the floor inside and the dpm exits to the outside about 200mm below floor level. I've excavated the area around the doorway to install a step and found there's about 300mm of dpm flapping around in the breeze - and presumably been channelling water back into the slab.
My question is what to do with the dpm? My first thought was to bring it back up the front of the slab, fold it over the top and somehow seal it to the top. And maybe install a timber threshold over it (currently there is an Exitex threshold channel thingy which mates with it's other half on the bottom of the door which actually works at keeping the weather out but leaves about 75mm of the slab exposed to the elements!).
Am I right in thinking that maybe this is not how a dpm is normally terminated at a doorway? And how should it be done?
I've searched high and low on the interweb for an answer and got precisely nowhere so I'm hoping that someone on here has experience of old properties and can point me in the right direction.
Paul
Paul
