Newbie_Neil
Been thinking about what to enter for a while now and decided to try something new (to me anyway). I've never done any laminated curves or veneering so am going to try a veneered bowfronted small chest of drawers.
I played around on CAD (Alibre Xpress) to get a curve I liked the proportions of, printed it out and made this former. It is 4 bits of MDF screwed and glued together, roughed out on the bandsaw and smoothed on a drum sander in the drill press. The front of the former has been waxed to hopefully prevent the veneer sticking to it. Also pictured are the 3 pieces of 3mm MDF and the American walnut veneer for the inside face of the drawer front. I will veneer the edges and front later. I have no idea if this is the correct way to do this and am making thing up as I go along. I am using the glue pictured which is a waterproof (D4 grade) PVA. I used this as I have read somewhere that this will not creep which can happen with ordinary PVA.
Here is one of the drawer fronts clamped up.
And here is one I prepared earlier.
Here is a stack of 12mm MDF for the carcass (I can feel the cringing going on)
I bought the veneers from Vale veneers and bought this iron on glue film as well for the flat surfaces. Also shown is my hi-tech veneer application tool (OK it's a £5.99 iron from Homebase)
This is a piece of MDF with the glue film applied, you just lay the veneer on top then iron on through the backing paper to protect the veneer. Seems to work a treat, you just have to make sure there is no dust or other lumps in the layers. DAMHIKT
