Hi all,
I have a couple of design questions that I'm struggling with. I am building a pair of cabinets in alcoves, 900mm high closed cupboards on the bottom and 1100mm glazed units above them. The alcoves are 900mm wide. The cabinets will be painted.
Is there a rule of thumb for how to do skirting/plinth for a built in? My existing skirting (very plain with just a round over on the top) in the room is 225mm (9") high; I could continue this around the front of the units; but, will lose a lot of the useable height. I was thinking/hoping that half that height in a similar style would work?
Second question: how narrow can I make face frames and rails and stiles? I am using 18mm ply carcass and probably 20mm thick tulipwood/poplar for the face frames. Typically I use a face frame of 50mm width (with a cock bead applied adding 10mm to the width) and 75mm shaker style doors; but, that's never been with glazed doors. I want more glass and less frame.
Any advice gratefully received.
Regards,
DT
Regards,
DT
