batcrazy
New member
Almost there.... anyone got any experiences with the Elektra Beckum TYP BAS450 WN
I've read good and bad
Max height of cut 300mm
Throat capacity 440mm
Saw blade length 3380mm
Saw blade width 6-25mm
Saw table size 550X600mm
Saw table tilt stepless from 90-45 degrees
Blade speeds 68-176-375-967 m/min
Height 1920mm
Width 845mm
Depth 745mm
Table height from floor 926mm
Weight 127kg
Motor 1.1kW/1.5hp
Height 1920mm
Width 845mm
Depth 745mm
Weight 127kg
Motor 1.1kW/1.5hp
