Yet another sharpening thread.....with a difference
MrTeroo
3 Sep 2016
Worcestershire
Does anyone sharpen their Gillette Sensor Excel or similar blades?
They cost a fortune and only seem to last for two or three shaves. Any jigs or tips for attempting this?
Throw the lot away and get an old fashioned double edge razor, a decent shaving brush and traditional shaving soap. Cheap as chips and the blades when well cared for last for quite a few shaves.
I use open (cut throat) razors), more expensive to kick off, and a steep learning curve, but great when you get to know them.
If you don’t fancy stropping a cut throat, get a feather (cut throat) razor, Like an open razor with a disposable blade. I like these the best, as I have not changed the blade in about four years.
You could go for a pack of cheapies from Asda or Tesco. They work out at about 10 pence each. Being only twin bladed, they probably don't shave as closely as a 4 blade Gillette to start with so you may want to go over the same area twice to get the same effect, but - after a few shaves both types will be starting to lose their edges. With Gillette, it is tempting to keep on using because they are too expensive to throw away after only a few shaves, whereas with cheapies you just get a new one fom the pack of ten. So overall, I think you actually get more good quality shaves from the cheap razors than from the big brands. That's what I do anyway, don't much like the look of a cut throat near my face.
K
K
Yes I have tried that but my sensitive skin just cuts up if I use the cheapo ones.
I've just been looking on youtube and stropping on leather or denim seems to be the way. Maybe I am overthinking it. I was imagining some method akin to chisel edge sharpening with a diamond stone in miniature.
+ what Morturn said - there's lots of good quality DE blades about which cost about 30p and last several shaves.
Rod
I do already use a shaving brush and soap. Which double edge razor? Do you sharpen the blades?
I use a Gillette Slimboy and a Merkur Futur razors. Edwin Jagger make good ones too.
At 30p for a weeks shaving it's not worth the bother of resharpening them.
Rod
cheap ones from lidl, i only get 1 shave from whatever blade i use
have sensitive skin and only ever cut myself once with the lidl ones
Steve
I find a new surform blade gives the closet shave and lasts the longest [SMILING FACE WITH OPEN MOUTH] I haven't shaved in years. I always use to get skin rash, so prefer short stubble.
Coley
Sent from my SM-G900F using Tapatalk
MrTeroo":2rq255ui said:
There are quite a few on the market, Wilkinson Sword are a good blade, they work out at around 13p a blade.
Derby or Astra aren’t bad blades either, and you can still get Gillette 7 o‘clock
Feather are a Japanese double edge razor blasé that are exceptionally sharp. You need to gain some competence to use these.
I personally don’t sharpen, I just have a good well practice shaving routine. I use a pre-shave cream, Proraso and shave just after a shower or bath. However, people do sharpen double edge razors.
Rub the blade around the inside of a wet glass, back and forth. There were a number vintage of razor hones on the market, the Lillicraps razor hone was one, made from green glass. When they discovered it was uranium that coloured glass green, the then call it the Lillicraps Uranium Green Glass Patented Razor Hone/Sharpener.
This guy on You Tube knows quite a lot about traditional shaving, as you do. He has a You Tube channel
https://youtu.be/ufG1dPmVo8Q
https://www.youtube.com/user/mantic59
There's a device called a RazorPit which supposedly freshens up the multi blades. They claim you can get 150 shaves out of a blade using it??
Personna is another good make for blades.
And of course there is a forum- Badger and Blade :)
Rod
Rod
Thanks for that. The RazorPit looks interesting.
They seem to focus on cleaning the coating of dead skin cells from the blades. I saw a YT video that approached this in a different way by leaving the blade in a cup liquid soap.
I think I may experiment with two methods together. Soaking in liquid soap and stropping on suede leather.
Looking at the RazorPit ( which you can get for £9.99) I would have thought a fine slate would do the same job?
Rod
Would that not be too hard? They use a soft polymer to allow the head to make contact.
FAQ from their site:
Gillette razors have metal on each side holding the blades in place and you can not push hard enough to actually clean the blades as the metal prevent this.
Yes it can! The RazorPit has the same softness as the skin. This means that if you are able to shave with it, the RazorPit surface can come into contact with the edge of the blade. It is hard to believe, but it also hard to believe that you have to pay so much for razor blades.
