Jacob
What goes around comes around.
Existing wood stove has long length uninsulated flue nearly up to ceiling, then insulated through room above and gives out loads of heat in both rooms.
New house has normal masonry flue/chimney with gas fire, probably lined, probably was an open fire originally.
Another wood stove proposed - wondering about opening front of the whole flue top to bottom 3 floors, to extract max heat from steel flue therein, probably just insulated where it goes through two floors.
Seems an obvious idea - has anybody done this?
