For all the burners/binners out there, I would like to recommend getting a compost bin. In case you have not already discovered the joys of composting you are in for a treat - it is arguably the pinacle of mankind's endeavour and every part of the process is enjoyable: sourcing and gathering compostable items, chucking them in the compost bin, periodically mixing them up and then putting the result on the garden.
Once you take up composting you will probably want to give up another hobby to make time for it, so don't say I didn't warn you!
Many people do not realize the importance of adding woody material and just put in e.g lawn mowings, which will create a disapointing sludgy/smelly result. Wood shavings/wood dust is an ideal material, and in case you do not have a lot of this you can also add torn up cardboard.
It is is not very likely you will need any more thrills in addition to the fundamentalss, but in case you do, and you own a petrol lawnmower you can use it to chop up woody garden debris for inclusion in your 'mix' also.
PS when I used to live in a flat I had a wormery under the kitchen sink, so even those without a garden are not excluded (although tbh a wormery is not really up to wood shavings - you really need a big compost bin).
