Where to buy non countersunk screws
MarkAW
21 Aug 2020
Worcestershire
Where can I buy screws that aren't countersunk?
I often find I need to fasten a piece of hardware or similar situations where countersunk screws are not appropriate.
I can only seem to find countersunk or what I have found is very poor quality, (must be made of soft metal as they strip easily).
I could do with a small selection of varying sizes.
Have you tried cup washers, just a suggestion, I assume you mean wood screws and not bolts.
Try here: kayfast I've bought from them before, though not roundhead screws - seemed good to deal with...
Thanks, yes I have a few of these left. I do use them sometimes, though they're not the best aesthetically.
General purpose screws. Mostly wood, sometimes wall plugs.
Thanks. Looks like they have a few.
:unsure: Seems they are generally called 'flange' and also 'pan', with pan tending to be wider and flatter heads
Flange means the head is shaped as if it has a washer (the flange) under the head, so they are wider. Much better for a fixing on timber as they resist pulling in. Panheads are smaller and neater and better if bearing on metal anyway.
I must admit to having used self tapping screws before now. Generally intended for use with metal, most have a good deep thread an bear some similarities to wood screws. They are available in Pan head and in a variety of colours.
geoff
