Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 74
I'm pretty certain you can get something. We have a Vaillant "system" boiler. It's condensing, so it's efficient, but it's NOT a combi (instant mains-pressure hot water). It looks like most modern boilers - a 4" small flue that's also the air inlet. It does hot water via a piping coil in a pressurised hot water tank.
Worcester Bosch are a good make (I think Vaillant's reputation for being good quality is undeserved), but you might also consider Keston, an all-British company: they are physically small, and their inlet and exhaust piping can be split into two separate small plastic pipes, so they will, for example, fit on internal walls neatly. They're popular in churches and small public buildings because they'll fit almost anywhere. I'd say a Magnaclean is just good sense, and you don't or shouldn't need lots of radiators replacing, as long as they are cleaned and in good order. A proper cleaning flush-out is common sense though, as is using a good quality corrosion proofer (after some wasted money I've gone back to Fernox).
If you find someone by local recommendation, that's probably much better than just a good price. I once allowed a plumber to do one of our bathrooms, after my wife chose them. I ended up redoing almost all of the piping myself because of leaks! A good plumber has two characteristics (a) skill and experience, (b) honesty.
I'm an amateur plumber: I'm no longer allowed to fit my own boilers, but I do radiators and water plumbing as the need arises. Often a plumber's idea of reliability isn't that of the householder: how many times has he been called back to the property in the warranty period? You're interested in how much it will cost to maintain over, say ten years. A good local plumber will know about that...
