What’s the very best caulk / sealant / adhesive
deema
14 Oct 2011
Cheshire
Happy New Year, I’ve now got a major project of painting and decorating to start 2024🤪 and I just love painting….not! Anyway, this is for our forever home, so I want to prep for paint using the best longest lasting products I can find. Ive got skirting, architrave, windows etc to prep. I’ve also bits in the bathrooms to seal up.
I don’t want it to crack, I want it to be paintable, for the bathrooms I would like it to be mould resistant
What’s the best products to use. I’ve been looking at CT1 and BT1, any good? Anything better? What would you use? I’m not after budget, I’m after the best of the best🥴 (any MiB fans?) (UK purchase)
only a DIYer , but have used CT1 for years & BT1 on bathroom , ensuite recently - when it was released.
for caulk i use NEMESIS MIGHTY DECORATORS CAULK
CT1 i have used in cast iron gutters joints works great and various other exterior/interior places , also good as an adhesive
This is my goto silicon for most jobs
BUT nemisis is instantly paintable , so used on skirting and other gaps interior where painting was required.
but as i say - just DIY and not trade
Not yet tried but when I was looking for adhesives I came across this one. A hybrid polymer jobbie but this is a combined adhesive and waterproof sealant.
It'a about £1 a tube dearer than the adhesive only equivalent.
https://www.everbuild.co.uk/products/adhesives/hybrid-sealants/stixall/
If you are going to use a lot, try a couple of different ones first before going all in on one formula.
Everbuild make a newer formula of the combined adhesive / sealant called EB25 but I found that pretty thick. I'd want one of those high leverage caulking guns to squeeze that out of the tube.
If you are only filling in gaps for decorative finish and not structural then decorators caulk is great and designed for the job. Fill gaps and wipe over to give nice paint ready finish.
https://www.mypaintbrush.co.uk/geocel-painters-mate-310ml
If you want to make life easier then buy some decent brushes as they make a lot of difference as I have found out and buy paint from a trade centre not a local shed. I now only use Jonhstones as it is a good quality for the price, much better than Dulux and better than crown plus they mix to any color you want. Brushes then look at Picasso
https://www.mypaintbrush.co.uk/buy-paint-brush/angled-cut-brushes
and for laying off use
https://www.mypaintbrush.co.uk/buy-paint-brush/Laying-off-brushes/staalmeester-one-1050-05
and don't forget the bib and braces as it might make you look and feel the part.
Does make you wonder what we did we did before stuff in a tube came along.
My old work buddy always said "Its not down to the decorator to make your work good"
I don't know how many different types of caulk I've used over the years, but I do know I've always needed more than one application.
This was highlighted by the refurb I did on our previous bungalow. I spent about 12 months on an internal re-fit of all second fit along with built in furniture. When I finished I went back to the start and re-caulked extensively. When we sold a couple of years later nothing had opened up again.
Colin
Colin
It's often easier and better to accept from the beginning that it'll take two hits and just pump some in and let it dry without attempting to finish it.
Seems to me that's long been forgotten how too.
I regularly get told by my other half, (she works with me), and work mates that "Your not making a @@@@@@@ watch"
"Yeah there's meant to be a gap, it's better for the caulk" is used a lot these days............ :rolleyes:
I’ve found that many caulks are the Same , I avoid ghe really cheap and the ridiculously expensive - ever build is good but so is soudal , toupret is my go to filler for bigger holes and gaps. If using caulk in old plaster gaps then a hoover and crevice tool will work wonders to remove any excess dust . A spray with a small pressure sprayer ( old kitchen cleaner spray bottle ) washed of course will dampen the gap and help the caulk adhere , a 2nd coat if needed and a wipe with a warm damp cloth to finish ..
Some build procedures were different - skirting and architrave were fixed before final plaster.
Otherwise fill materials were generally various blends of dry powder such as chalk, cement, gypsum, wood dust, etc in oil, water, glue, casein, shellac, egg, starch, or mixed emulsion binders. The resultant 'stuff' might be termed putty, gesso, compo, stopping, grain filler, and a whole range of other trade or art specific terms. These mixes can be made setting or non-setting, waterproof or soluble, fine or coarse.
These recipes were learnt, according to trade, as part of an apprenticeship, and were often mixed from raw material as needed.
The post WW2 skills shortages, combined with the rise of DIY culture and industrialisation/deskilling has resulted in a proliferation of commercial products from Polyfilla through to modified polymers via epoxies, silicones etc.
As much as I turn too premixed lightweight fillers and modified polymers for quick DIY results, in my oil painting I still return to the old materials and methods.
I follow a guy on Twitter (X) Gary Burton. He's a professional painter and decorator but in a different class to most (light blue touch paper). He often posts tips about paints, sealants, caulking materials etc. His restoration of Victorian plaster cornices and roses is fascinating. https://twitter.com/TheOfficialGRB
