TheTiddles
Right, this piece is finished but I may post this in installments as there's a lot of pictures to explain.
I'm using my new router table for the first time, with a curtain fence as it's simple to make.
The walnut boards have been sat waiting for an application for years, so here it is, I took a little off either side then left them for another couple of weeks before cross cutting and shooting.
This design is rather much inspired by Ian's work, I wouldn't normally go for this kind of construction but it works for him. So here goes...
The fence works perfectly, the workpiece is totally supported right through the cut, the final cleanup is done with a shoulder plane
The top is going to be walnut burr, first time I've used it and seeing as I've got about a dozen bundles I hope I like it. This has been flattened in a press for months having first been sprayed with 10:1 water and glycerin. I hate shooting veneers, I always make amess of it, so I'm using an oversize marking knife from Pheil, it has one bevel only and it works great. It needs a handle but for the moment I'm using in the buff.
Here it is just prior to going in the vacuum press, hinged with tape to stop it skidding.
I'm using a bit of leftover 6mm WBP as it's going to be veneered both sides, on the right is some gorgeous rippled ash I now have lots of too now!
The rebate for the top is cut with the table saw, because of the design of TS-200 the riving knife has to come off to do this, I need to make one that's sub the top of the blade.
However, to keep things safe I'm using a semi-circular feather board which keeps the piece down, pulled into the fence and covers the blade, not bad for £5.
First trial fit and I like it. this sort of construction doesn't hold itself together like dovetails would but it's quick, clean and allows you to focus on details and simplicity instead of complex joint making
