Molynoox
Hi All,
I'm just retrospectively wondering about moisture barriers in walls, I recently built a 9x4m outbuilding, using stud walls, OSB sheathing and 100mm PIR insulation.
I did use a moisture barrier in the roof, as this feels like the key area to control damp, but I didn't bother in the walls, I am now wondering if this was smart or not and wanted your opinions on the matter please
Wall Detail
my wall build up is as below - as you can see, the PIR is pushed up tight to the OSB sheathing on the outside, therefore minimising chances of condensate forming as the 25mm air gap is on the inside (warm side). The only thing separating the air void inside the walls from the ambient room temperature is 12.5mm plasterboard so I figure that the temp gradient wont be very significant. You also have 100mm PIR until we get to a cold surface (the OSB sheathing) so I don't see that the air will get much chance to turn to condensate.
Note: the dimensions on the graphic below are not accurate, I used 125mm timber and 100mm PIR (not 100mm timber and 60mm PIR as shown)
Note: the green moisture barrier shown in graphic is the moisture barrier in question - I put it in the original drawing but decided not to use it. I did use the red tyvek house wrap, but I don't think this is relevant to the discussion as that is more to stop water getting in
thoughts?
I also have a heat pump running a heater/air-con unit which circulates the air inside the room, which I assume helps with moisture control, and the doors and windows have trickle vents.
appreciate your thoughts on this, cheers
Martin
Wall Detail
![wall section - fire rated 1.jpg wall section - fire rated 1.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/108/108975-wall-section---fire-rated-1.jpg)
![wall section - fire rated 2.jpg wall section - fire rated 2.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/108/108976-wall-section---fire-rated-2.jpg)
thoughts?
Martin
