veneer mdf plywood or timber
phil2010
16 Sep 2010
Hi what is the procedure for applying veneer to plywood mdf or timber ,i am talking large sheets of veneer thanks.
Fir the first two you would be best off buying it in ready veneered. Failing that Edge joint your leaves of veneer, tape and glue the edges, glue your substrate and then bung it all into a large vacuum press. and don't forget both sides need similar treatment.
Same sort of process for solid timber just take into account any movement
Jason
