Adam Pinson
If you're going to use CA glue so seal a workshop injury, don't use accelerator spray! I regret that move !
Perfect .... apart from the heat !I expect hot melt glue's probably not a great idea either.....![]()
You have to be careful with that stuff, you need to clean out the wound first, with a sterile cleaner. If you don't and you trap something nasty under the liquid skin, it can cause all sorts of nasties.The best thing is Germolene liquid skin, is antiseptic, seals cuts instantly but stings like hell for a few seconds!
Dave
But that is a real bu..er to get back off.Hockey tape is the way forward.
It mostly sticks to it self so I just push some scissors up the side and try not cut myself again. I have a superglued finger right now from a 0.2mm carbide insert...But that is a real bu..er to get back off.
