Following on from my previous thread about thin materials, can anybody point me to a jig for trimming thin strips?
I saw one using a plane iron at a show once but cannot find it?
Incidentally I found my TS produced the most consistent results - using the BS to cut them to width. We are talking about 2mm x 4mm.
I tried sanding them on my oscillating sander but will need to make up a better jig which keep the section from flopping about - i.e. one to hold the strip against a fence and to control the depth of cut (sanding)?
I also made some coving - the best method seems to router the profile first then cut to size. Cutting to size first 7mm x 7mm then routing using feather board, produced inconsistent results?
Rod
Rod
