thicknesser driving me mad
9 Sep 2011
uxbridge, Middlesex
hi guys
i have a record pt260 planer thicknesser the problem is with the thicknesser. i am getting snipe on both ends of the board and in the middle of the board slight ridges i have taken some pics. baldes are just been sharpend and they are set useing gauge provided with
the mechien. could it be the rollers :? i have noticed that there is some play in thicknesser bed 0.5mm, not sure if it should be there, opposite corners (diagonally)i.e when corner A is flat on surface-corner C (opposite) is not touching surface with corners B & D flat (whether A or C are flat on surface) on surface and vice versa (A & C) .
If the bed is the problem then how can i fix it :?.
i hope i am making some sence. cos i dont know if i am............ :?
thank you
ahmad
Hi
How old is the machine ?
when you say you have set the blades ? how and with what ? a photo will help
are your boards supported on roller stands on the way in to the thicknesser and on the out feed side as well ?
hi blister,
thankyou for you quick replay i got this planer thicknesser second hand about 9 months a go i think it is 4 years old the pices i am thicknessing at the moment are 47cm and i am getting snipe at both ends about 4.9mm. i am have attached a pic of the gauge i am using. i dont have snipe when i am planing.
hope this helps
best regards
ahmad
hi steve thanks for you replay i have viewed this clip. but the problem is still there even on small 47cm pice of softwood. snipe is not there when i am planing.
ps: i always view you youtbe video and i think you videos are the best.
ahmad
First thing I'd try would be to lift the board very slightly as first contacts the infeed roller and, then again, before the board leaves the outfeed roller. I think Steve mentioned something about this in his video, if my memory serves me well? It can make a difference.
Otherwise, I'd suggest making a 'false' bed from a sheet of 18mm plywood, with a piece of timber attached to the underside of one end so that the bed cannot be pulled through the machine. Of course, you'd then have to compensate for this on the scale by allowing for the thickness of the ply. But, you could make it longer than the current table, which should help to reduce snipe.
My AW106PT has rollers on both the in and outfeed. Rollers aren't essential; it's purely the extra support they provide in keeping the board supported. Hope this helps. :)
