• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Table saw mitre guide
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
It's not something I would use all that much, but would be handy now and then.
I don't believe I ever had one for this saw.
The track is 12mm.
A cheap and cheerful solution suits me best.
    225.1 KB
    164.4 KB
I had problems getting a mitre fence to fit the sliding table on my casadei panel saw. In the end I machined the slot wider to take 19mm track fittings. I used a router and cleaner up with files but I was only taking about 2mm
Make one out of ply.....and the must have for those small 90° cuts is a Frits and Fran.
It may come to that.
I googled Frits and Fran. and found a utube video for a jig, if that's what you mean I'll watch it later, Still some work to do even if it is Sat night.
Wouldn't want to try that, but I guess I could get someone more experienced to do it>
Is it possible to take a mitre gauge you like and replace the bar with a narrower one? Keep the old one if you ever want to switch back. I've accumulated several along the way and all would take a narrower bar and still have enough meat around the threads.
It's an unusual size, meant for a T bar fitting, but they do exist. Measure the full profile of the track and search around. If you are not used to metal bashing I would not attempt to widen it yourself, and definitely not if it is cast iron - that needs a miller.
the standard is 3/4"/19mm. unfortunately almost all UK saws are non standard. I think it is much more common on US machines,
The 3/4" bars that are on my mitre gauges have a washer on a recess to fit the T-slot. It is only to keep the far end from lifting. I have never had that happen on one yet so I wouldn't worry about it but everyone is different.
i think that might be my best option.
