Table saw blade runout and cut width variance
DBT85
19 Dec 2015
Pershore, Worcester
Just a quicky really.
Make a 600mm long cut on your tablesaw to any width that you can chuck in your calipers, so say 100 or 150mm. How wide is the cut piece at either end? Are they identical? 0.1mm out? More?
Also, how much runout do you have on your blade?
I only ask as this Sip I picked up has a 0.15mm runout on a 250mm blade, and also has a 0.2-0.3mm variance in width of a board when measured at either end.
