Hi all,
I'm looking for a bit of advice.....
I'm in the middle of building a small office in my garage. I'm building three stud walls (the other being the existing cavity wall of the house). The plan is to insulate the stud wall, and to use an electric heater if the office space. The walls will be glad in OSB on both sides.
What I'm not clear on is whether I need to apply a breather membrane to the 'external' face?
The external faces are all inside of the garage, so won't we exposed to the elements.
Do you think there is a need for a membrane? And if so, would it be better to install the membrane before the OSB on the external face so that I can still use the raw OSB face for shelving etc.
Thanks in advance!
Thanks in advance!
