mack9110000
I've been asked by a friend if I can repair a standard lamp.The lamp is in 3 sections and has been turned & carved from teak,maybe Burmese.The problem is,the carved thread from the middle section into the threaded hole in the base was broken off recently.My question is,can anyone recommend a glue which will be strong enough to hold where the break has occurred?The base is 12¾" dia with an 1" threaded hole,the broken threaded piece is 1½"long with a ¼"hole through the centre,this piece has been broken off the middle section,which steps up from 1" thread to 1¾ dia turned ball with centre hole.I hope this explanation is enough.Anyone help?
