Sip 16" scroll saw
karfeef
26 Jan 2014
Liverpool
Hi. Does anyone have the sip 16" scroll saw? I'm finding it a right pain in the proverbial when blade changing. The top is easy, so inside cuts aren't too bad, but the bottom is a nightmare to see if you have the blade in the right position.
I remove the table insert, undo the little side panel. Am I missing something that will make life easier?
Sent from my GT-I9300
Hi Karfeef, I have a SIP 01373, and have only just started scrollsawing.
It is a pain, but after removing the side panel and replacing the small hex bolts with some wooden knobs (made from some scraps, with m4 threaded rod through the middle and some bolts) it's easier to change the blades. However, when applying tension it often pops the blade out (because I have no idea how high/low in the clamps the blades ought to be positioned when tension is off). However, as I do my scrollsawing outside, I've not had much chance to practice recently!
Sorry, that's not very helpful!
I've got the 01928 and I've found I need to shine a light in from the side to be able to see in from the top. Not very intuitive, but it'll do for the time being :-|
Other than that, I really like the saw. Scared to try anything that's considered a 'good' saw in case I get shinyitis.
I ve got a sip scrollsaw tried everything with the clamps got so frustrated with it Had about five sets of new clamps on it tried indexing lever worked for a while but kept stripping the threads in the end I gave up and bought a second hand delta with the quick set clamps it's a shame because the sip isn't a bad little saw if manufactures put half decent clamps on there machines I'm sure they would sell a lot more
