Dan Steely
I'm suprised but the lack of support from Proxxon. I thought they were a proper German company...
Clogs: Do you have an example you could share?
I'd like out for a naerok mill if it's anything like my pillar drill then it's a solid machine!150's - 60's...there were quite a few diff manufacturers of beefed up pillar drills that can be used as a lightweight mill....and bench drill......
last time I viewed one it was around £300.....
not a bad price considering.....
because of the rise in home workshops small'ish machines are getting unaffordable.....
I have one which I use for model building, for which it is intended. I've fitted thrust bearings to the X-Y-Z shafts & replaced the spindle with an E11 collet chuck enabling use of small 1/4" or 6 mm router bits. I use it on wood aluminium & brass. The small wheels are no problem for me. Many accessories are available, inc. a dividing head. I have another small mill I built using a Makita trim router, which I use for bigger jobs.I've been just looking at the tiny Proxxon milling machine. Does anyone have experience of this machine?
https://www.axminstertools.com/proxxon-mf-70-milling-machine-371104
...and then the drill chuck is unlikely to hold an end mill securely enough...
A 4mm 4 flute endmill, cutting ali should be up around the 12-16000 rpm rangeThe other issue regarding my pillar drill (BOSCH PBD40) is the speed range (200-2500) and am not sure if it's slow enough or have enough torque
I have the Cowells 90ME with the end mill attachments and it works very well indeed but it's a watchmakers lathe and limited capacity.Although pricey, I've got my eye on the Cowell's lathe and mill. Saving up my pennies...
Good luck,
Woodspiral
I tried a sanding drum in my Axminster pillar drill and within a very short time the chuck dropped out of it's taper. I did the same as a previous post said, and fitted a bearing below to support the sanding drum and reduce lateral forces but in the end I just bought an oscillating sander when on offer from Rutland tools. So I think milling metal is way out of the league of a drill. Luckily I have a mill, and space to put it. Half a ton of cast iron.Pretty much my reasoning for not using things that need lateral pressure, grinding wheels, wire brushes etc in my drill drivers. I can't imagine the designers allowed for this eventuality when specifying the bearings, and designing the bearing housings. Best get the proper tool, maybe an angle grinder.
