B Baldhead Established Member Joined 7 Jun 2012 Messages 1,509 Reaction score 0 Location In Limbo (Northumberland) 30 Mar 2016 #1 I intend to use Sikkens Cetol Filter 7 Pus on an oak cross I'm making, this is to stand outside, can this be applied direct to bare wood? Thanks Stew
H Harbo In Memorium Joined 13 Nov 2006 Messages 5,548 Reaction score 5 Location Hampshire 30 Mar 2016 #2 Use Sikkens HLS as a base coat first then 2 coats of Filter 7 http://www.duluxtradepaintexpert.co.uk/ ... s-hls-plus It's excellent stuff I use it on my exterior woodwork - doors and frames. Rod
marcros Established Member Joined 11 Feb 2011 Messages 11,302 Reaction score 745 Location Leeds 30 Mar 2016 #3 Stew, Are you buying the product for this job alone? I had a bench to do, and found that the Osmo equivalent was available in sample tins, which was much cheaper. I used a http://www.wood-finishes-direct.com/pro ... ection-oil and a clear uv oil over the top. Mark
F Flynnwood Established Member Joined 11 Feb 2013 Messages 524 Reaction score 129 Location Bedfordshire 30 Mar 2016 #4 You might find this experiment of interest? external-iroko-osmo-uv-oil-or-sikkens-cetolfilter-7-plus-t59500.html
