HappyPixie
Hi folks.
I've obviously lost my way, having spent most of my time in the 'woodturning' section.
I completed a cherry bowl yesterday which I sanded to 320 grit, brushed clean and then applied Chestnut cellulose sanding sealer after I switched the lathe off. I patiently waited the requisite five minutes before smearing a light coat of Yorkshire grit all over. Another short wait and then powered up for a couple of minutes of moving the pad over the surface to allow the grit to break down and abrade further and smoother. Then a couple of wipes with clean cloths while it was still whizzing round. Powered down and then smeared with Hampshire sheen. Another few mins and then powered up and polish off the surface with a few more clean cloths. This is the second bowl I've done this way and both times I've got a VERY smooth surface (lovely) but although there is generally a high gloss on most of the surface, there are patches of mid-sheen (see picture). I'm sure I'm following the instructions and I'm not applying too much pressure when gritting or sheening, so I'm stumped.
Should I apply more than one coat of sealer, grit or sheen?
The first bowl was given a light rub with red Mirlon and then hand buffed with microcrystalline wax. That's OK, but I want to know what I've done wrong in the first place.
Cheers all
Steve
Cheers all
Steve
![CherryBowlFinish_Small.jpg CherryBowlFinish_Small.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/61/61926-CherryBowlFinish-Small.jpg)
![CherryBowl_Small.jpg CherryBowl_Small.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/61/61928-CherryBowl-Small.jpg)
