Jacob
New Luddism. Awake and resist!
Had a hand basin waste pipe drainage problem for some time - tried all the easy things, plunger etc, cleaned out bottle trap, but no cure. Caused by lime scale (this a hard water area).
Got worse last week and thought time for a serious blast - ordered a gallon of vinegar first and ran steady trickle of hot water for half an hour or so with a trickle of dry caustic soda to open it up a bit. Had reverse effect - obviously dislodged scale which had merely jammed itself further down the system and stopped it off completely.
Now had basin filled to brim with caustic soda solution, also filling the pipes. No way to trickle in the vinegar - f***k!
Major plumbing job in the offing, and how to handle the caustic safely if I cut a pipe or whatever.
Then remembered my little Goblin in the basement - an old decrepit wet n dry vac which I just use occasionally as a blower - never used it as a sucker.
Dipped pipe into full basin - one powerful gulp all gone in seconds! Stuck it into plug hole, blocked overflow with a flannel - great gurglings and the blockage gone too!
Amazing - a year long problem gone in about 5 seconds!
2 gallons of mucky looking caustic soda solution, lime scale flakes and smelly gunge in the Goblin.
Thought it was worth mentioning - I hadn't realised how effective the wet function was and how potentially useful.
Henry do one - I'll definitely buy a wet n dry when I need another.
Boring story but I thought worth knowing!
Anyway it's the most interesting thing which has happened to me this Christmas, including the Morecambe and Wise show!
