routing question; round over bit
onlinename
9 Mar 2013
canterbury
Hey guys,
I have a 1.5mm Walnut piece that I would like to round over the edges of.
I can use my orbital sander or sand it by hand. Trouble is because I will most likely be making many pieces of 12cm x 6cm I was wondering if there is a bit small enough to provide a nice round over effect?
Is this something that wouldn't be recommended on the router?
Also I have a 3mm piece of ply & 3mm perspex. Is there a round over bit that I could use to round over all the edges, back and front to get a sort of semi-circle kind of feeling when you run your hand along the edges?
Appreciate the tips.
Many thanks
Charles
Hi Charles
In another thread last week i think, i linked to a wealdens mini cutter that had a 1mm radius. I think that was the smallest they do. I'm not sure i would want to route a piece that thin though. For the 1.5mm piece i would probably just sand it by hand, or you could made a block of mdf etc with a cove in it. That way when used with sand paper you will get consistent results.
