Niall Church
- Joined
- 22 Apr 2023
- Messages
- 167
- Reaction score
- 6
Looking to buy a small router table,not too expensive OR should I get an insert thingy?
At the moment I need it to out rebates in 2x2 and I think a table would be better than hand routing,so,I need a fence for accuracy. Any inserts or tables you could recommend?If you are tight on shed space then an insert on your tablesaw wing.
Takes up no extra space, could be cheaper than a router table, a nice big surface to work on and you can use the tablesaw fence to attach the router fence to.
Not really much to a router table at its very basic level. Something like this can get things done at almost no cost.
Very simple homemade router table for small projects - YouTube
Then the other end of the line are things like this.
The Best Router Lifts (2023) - Reviews by Woodsmith
Over the years I have used the hole in a sheet of ply when I had nothing else and I had a cheap benchtop table for a while. It did kind of all right but the table surface was a bit small so limits the size of things you can do. The high end stuff makes adjusting much easier and precise but at a cost. Kind of mind boggling just how much router stuff there is out there.
Regards
Then buy an insert plate that will cope with the weight of your router.
Insert this plate in a table and you're sorted. You will need a fence and
Update bought a small JRT-2 JET ROUTER TABLE.Looking to buy a small router table,not too expensive OR should I get an insert thingy?
Sorry ,jester,there's an update, I bought a JET JRT-2 ,router table,so if anyone can help with assembling ,would be grateful!Do you already have a router, by that I mean a 1/2" one, or even a palm router/trimmer?
You'd need a decent insert plate for the former and a 'diddy' one for the latter.
Trend sell a decent one, around £48 on Amazon.
Needs a fork lift to get it in the van?light enough to go on a shelf.....but
If using a router lift or insert plate from the likes of Kreg, Jessem, Incra or Woodpeckers it will be an imperial size even if the lift increments are metric. If going the UJK direction there inserts are metric so be aware you get more choice and good quality from the other side of the pond.Everything I've found so far online is in Imperial measurements and I prefer to work in metric.
