I bought a new (used) lathe today! It's a RS2 with Dart electronic variable speed (0-3000 rpm) and came with three chucks and some other stuff that I don't know what to do with.
As you can see, I need to rearrange the space to fit it in, but that should be an easy removal of the shelf/ worktop.
These are the lathe bits that came with it (I was also given a mask and some wood and other things):
It has all the paperwork from new.
I just got home and set it up, and it's running a treat (in the sense that it's running nice and quietly and smoothly - I can't actually use it as I don't own any gouges yet. hmmm).
Two questions if I may:
How much tension should there be on the drive belt? I allowed the motor to rest its weight on it and slackened it a tiny bit and then tightened the bolt holding the motor in place, should that be fine?
What would you recommend to sharpen gouges on a budget? I've read about different systems but hope to find a grinder and guides that aren't too expensive. (I hope asking about sharpening in the turning section isn't like that question when it appears in handtools?) (hammer)
I'm delighted with it - half the price of the lathes I had been looking at new, and it's only been used for hobby by the same owner from new. Thanks to all who advised in my other thread in this part of the forum, especially Chas who kindly replied to my pm about the lathe.
C
![_MG_6747.jpg _MG_6747.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/50/50568--MG-6747.jpg)
![_MG_6742.jpg _MG_6742.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/50/50569--MG-6742.jpg)
![_MG_6745.jpg _MG_6745.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/50/50570--MG-6745.jpg)
C
