• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Record Power PT260 10" x 6" Planer Thicknesser
focusonwood
12 May 2015
London
Hi All,
I’ve decided to sell my Record Power PT260 Planer Thicknesser.
There is some wear and tear (listed below) and it needs some fettling to properly align the blades so that it cuts square, but someone with more skill and patience than me would probably be able to achieve this! I’m also including a knife setting jig.
Wear & Tear
  • Broken yellow plastic feather guide on the end of the blade guard
  • Broken caster wheel on base
  • Broken switch cover
  • Some surface scratching on tables
  • Screw missing on outfeed table locking arm
Some of these can probably be repaired or replacement components sourced from Record Power - these issues don’t impact the machine and it works fine.
It works fine, but to be honest I just don’t have the skill or patience to get the blades set properly!
£200 cash on collection from south of Kingston Upon Thames.
I should have mentioned, I still have the missing wheel and switch cover, and will hand these over to whoever decided to buy it.
I’m interested.
How much of an issue is the missing out feed locking screw ?
Is that pictured in any of the photos ?
Ta
Hi,
Yes, the picture numbered img_3174 shows the missing screw. This is one of two locking arms that rotate inwards to lock the outfeed table in place. It should be relatively easy to replace, either with a similar self tapping screw or a small nut and bolt.
It doesn‘t seem to cause an issue, so i haven’t bothered to replace it.
Someone has agreed to buy it, just waiting for collection next week. I’ll update the thread once it’s sold.
