I have a dml320 lathe, out of warranty. It has just started, to switch off and on by itself. When I look at the speed readout it is constantly changing and is obviously not correct. Sometimes it shows 05 on the readout, this does not feature in the user manual as an error code.
Also when it has stopped and you turn the hand wheel it will start up.
I phoned Record and they said it could be the sensor is dirty, I have checked and cleaned just in case. Otherwise the advice is a faulty switch unit, or the motor. I really would like help if anyone has had similar problems, as I do not want to buy the switch unit and then discover that the motor is faulty.
