RossJarvis
For whatever reason I've usually wiped fresh PVA off joints with a damp cloth. I've found with Blue Evostick that this causes a reaction that blackens the oak. Has anyone else noticed this, what should I do instead?
woodbrains":2yai6ii4 said:Hello,
I think there must be some iron or steel involved somewhere. Perhaps a contaminated cloth or impure water,
Mike.
cedarwood":3u4xi2q4 said:It's funny this post should come up just now as I have had the same thing happen to my latest build, on all my other projects i have allowed the glue to set then removed any excess which was all fine. On this build I decided to wipe off the excess with a wet piece of paper towel and on all joints where I did this there was a blackening of the oak, conclusion was that the contamination came from either the water or the sand paper used. I was using titebond 3 ultimate for the first time due to it's longer open time so went back to premium 2 but it made no difference.
RossJarvis":gtz3gcgr said:For whatever reason I've usually wiped fresh PVA off joints with a damp cloth. I've found with Blue Evostick that this causes a reaction that blackens the oak. Has anyone else noticed this, what should I do instead?
Bodgers":240vt21s said:I don't think it is the water content that causes the blackening... unless your water has high levels of metal in it or something.
