Pulleys and taper locks, any help
DennisCA
26 Apr 2014
Finland
I got an old AEG motor that I need a pulley for, the diameter of the shaft is about 28.3mm, such a metric shaft size does not exist I was told by the local company I bought a pulley & with a 28mm taper lock from (it did not fit) this is supposedly 1" 7/64ths in imperial. Anyone know if I can find such a taper lock bushing? Or is this something non-standard, it is a very old engine, perhaps 1960s.
I reckon that you should look at a 1 1/8 inch bush. This will be 0.015 inches larger than your 1 7/64 shaft. You could shim the difference with a shaft repair sleeve.
28 mm = 1.1023622"
28.3 mm = 1.1141732"
1 1/8" = 1.125
1 7/64" = 1.109375
HTH
I've also considered taking sandpaper to the current bushing, or to the motor shaft to get rid of those .3mm in either direction
wizard":2zp8otxw said:
Machine a pulley to fit
+1
If it's an inexpensive motor, you could try the sandpaper. If the shaft isn't heat treated it'll probably work.
