Power tool cable management
RobinBHM
17 Sep 2011
Wst Sussex
I'm looking for ideas on how to make a decluttered workspace set up.
I'm thinking of: cutting off the power leads and fitting quick connectors (Festool seem to have got my idea.....)
Any ideas of how to manage the cable?
I was wondering about a sliding rail for the cable overhead
Try a location above the workbench, work out the max 'stretch' needed for each of your tools over the main bench, using
a piece of rope?
Second one for use on an extension lead.
Hi
This problem of cable management has already been solved, it is called cordless tools. I like corded tools and do not mind the nice round yellow connectors.
6ft of power cable will always be 6ft of power cable whether it is one length or has an inline connector. The one thing you learn in electrical engineering is too minimise the number of connectors used because they just add something else to go wrong, and the inline connector will also be something else to snag. I can also add that the one thing I really dislike about my Domino 700 is that the cable plugs into it, I would much prefer a decent fixed cable via a gland.
The sliding rail cable management is called a festoon system using catenary trollies and often used on gantry cranes, another option is the drum roller, similar to what people use for garden hoses and also used for airlines.
I put flat connectors on mine years ago when I was using them at work in a place that had a far from adequate number of sockets - one thing I would say is to either cut the leads very close or more than four feet away as they get snagged on the edges of sheet stuff if they're anywhere in between. Ultimately I didn't find them very practical.
I bought a used bosch blue jigsaw a number of years ago, it was in great condition. The cable had been cut to the stump and a type of connector that I had never seen, used to connect to a 20 ft cable.
After a few months it gave trouble, it didn't trip the breaker but dropped power and dimmed the lights when used.
Done again thought I , it was probably just botch up so he could unload it.
Long story short, I found the fault was in the connector and a new cable fixed the prob and it's been going fine since.
I'm not a fan of extra / unnecessary connectors.
I would say don't.
I tried this idea on a bunch of my tools 20 years ago using a high quality connector design that is smaller than the neutrik and very reliable
I've gradually returned them all to captive, extra long, H05 or H07 grade rubber flex.
The issue is that a connector, however good, on the cord close to the tool tends to catch on the edges of your work and your bench.
Having the connector built into the tool doesn't create this issue.
It's an appealing idea but "been there, done that, wasn't convinced".
Spend less money replacing the factory PVC mains cables with longer ones made from 2 or 3 core H07RNF rubber in the correct cross sectional area. They don't cost much, handle well and make a corded tool nicer to use.
I
This is what I use for power tool strorage; Look what I've found at IKEA - trofast comination
1. The cable just goes in the box along with the tool, no winding up etc.
2. Any accessories with the tool also stay in the box.
3. The whole box with contents can be removed and taken to the job
Edit: IKEA put those words in the link not me !
I use either the case the tool comes in or a 'really useful box'
Perhaps there are a couple of inter related issues here : One is the reduction of the number of leads in the workshop and the other is the routing of those leads so that they don't get in the way.
I agree that the Festool approach is excellent but, not all of us, me included, can afford or want to standardise on Festool across the workshop.
My workshop is a double garage and I have fitted a counter balanced rotating boom to the base of the door lifter. Primarily this serves as a system to route a dust extractor pipe between the NV750 dust extractor and anything that I care to connect to it. I rotates and reaches most of the garage. I've also added a couple of 13A sockets to the end of it. That way, I can plug anything that I am using at a given moment in, have over head power connectivity and dust extraction. This largely does away with cable snagging on the edges of benches because the cables drop from above.
It doesn't take away the need to have loads of trailing power leads but I am loathe to cut the leads on my tools and standardise on connectors as it may void any active warranties. I do agree though, if I were to go down the standard cable route, super flexible rubber cables are a must - power tool cable as supplied as standard being very variable in quality and manoeuvre ability.
Back in the day when I had B&D corded power tools I refitted much longer cords to them - whilst that may seem to fly in the face of the OP it did make them much more manageable.
For my current corded tools, rather better quality, I did consider cutting the cords and fitting connectors but decided against it except for my track saw. The saw has a dust extraction hose with the power cable running along it with cable ties to attach. By fitting the cord connector I can easily disconnect the hose + cable combo and then use the saw elsewhere (for large sheets I have a fold up bench that I have to use outside)
Saw on the internet somewhere, a swinging boom mounted on hinges from the wall and over a workbench to carry power and dust extraction for hand held power tools. Looked like a practical solution.
I made one of those, works really well. Most of my stuff is Festool so the plug-it lead makes it really easy to swap between tools. I added a plug-it socket to my Makita sander to make that work with "the system".
Many thanks everybody, lots of useful pointers.
I hadn't considered the annoyance factor of having a connector catching on stuff.
However Im looking to incorporate power lead and vacuum hose, so maybe that issue becomes a bit different.
Has anybody tried hosewraps?
https://www.hosewraps.com/
It's painful using sanders with a power cable and vacuum hose when doing loads of parts for hours.
Fantastic!
Thanks so much for the pic, that's helped visualise it really well.
At first glance it looks like it's too restrictive as there's not much slack....but once consideration is given to the overhead articulated boom, I can start to see the area it covers.
Eventually it will build up your strength and you will not feel any pain. I have had similar experiences where you think this is just going to wear me down but you get to the point where it just becomes the norm. I can remember as an electricians mate, many many years ago being given several bundles of steel conduit and a sample piece, the task was to produce dozens of these double offset conduit lengths for the electricians to fit and they had to be perfect, god help me if I forgot to debur any of them. This was in the days of hand benders and hand threading with tallow.
Also welding, with gas or TIG you wrap the hoses/cables round your arm to support so best to just build up them muscles.
Actually I meant painful as in irritating....apologies for my poor use of language (I was falling into yoof speak)
The reason I'm interested in this is I am working with a friend to build a shaker door and face frame manufacturing cell with lean construction strategies.
For a semi production workshop Dougs idea may help but you will find it is the weight of the tools that give the bigger problem rather than the cables. In a production enviroment, ie assembly line what they do with heavy tools is put them on a counter balance so they are easily manouvered but do not feel as heavy.
I have made a few shaker doors with a domino 700, not that heavy unless you were using it all day long and I am no spring chicken so now I tend to use it on the baseplate rather than the adjustable fence, I think apart from the weight issue it also once setup gives me better and more repeatable accuracy unless you want to shell out £300 for a jig.
I think it's a great idea for tools that are also going to have a vacuum hose attached, the hose will always be the awkward part, not the cable/connector. For general use tools though just stick with the supplied cable.
many thanks for that -Ive had a look at tool balances -it looks like they could be used as part of the set up quite well.
